general FYI tip
  • general FYI tip
    when using aircraft stripper to remove paint from a shovelhead frame..... wear long sleeves
    the overspray from that stuff will burn the beejeezuz out of a sunburn
    don't get it on yer pee pee either....................oh, i may have said to much.............
      :fatbob:fatbob:fatbob:fatbob:fatbob:fatbob
      That'll learn ya!
        Will using aircraft stripper make the bike faster?
        LOL
          not sure about that, it makes you move faster tho.
          Get this, these folks bring me the frame of a 78 shovel that they are rebuilding
          needs stripped and painted. local paint guy told them $600 minimum.
          I told them $200 maximum if we use Acrylic enamel
          no sence in using clearcoat/base coat on a frame that is barely going to be seen
          my costs are going to be
          2 cans stripper $16
          little time with wire wheel in a grinder
          etch, primer, paint approx $50
          probably a total of around 4 hours
          the guy that brought it to me, has a shovelhead trike he built, says he will ride it to town to show me sometime, can't wait to see it
            Don't watch porno's after eating hot wings....
              Ive try all that stuff, peppers, various chemicals, oh!! friggen that heat stuff you suppoesd to rub on yer sore muscles some of that will bring a couple tears to yur eyes if you get some on yur willie
                Butter flavored Crisco makes it smell like you're at the movies...but it's hell to wash off...
                  I thought "aircraft stripper" was a stewardess that danced on a brass pole in the middle is the isle of a passenger jet.........
                    and if you Dave and DDB were called upon to customize some planes, you could be aircraft stripers.....right?
                      Don't think I'd pay money to see Dave dancing on a brass pole at 10,000 feet. DDB on the other hand...
                        OK..now i just had lunch...
                        i just might lose a few pounds today if i stay here
                          Why must you hurt...............?
                            Because I my momma didn't love me
                              Knew a guy in HS would cut a whole in the bottum of his popcorn cup at the movies(when they used to have buckets and not cheap bags) an would poke his willie in then let the girl go to munchin away till she found the prize. He got off that way.
