Bondo Trick!
  • Bondo Trick!
    Ever been working with Bondo or any other body filler and have it get hard to fast?:crazy
    Talked to the tech people at 3M yesterday about the problem I was having with the Bondo I was using on the hardtail frame, I would mix it and it would get hard, super fast, was tossing 50% in the trash! Tried cutting down on hardener and still had same problem!:aahhh
    The tech told me to store the tube of hardener in the frig and keep it cool, this would slow down the chemical reaction and give me more working time with the product. He said that high heat and high humidity would make it harden faster so by cooling the hardener it should help!:help
    Well after letting the hardener sit in the frig for two hours I tried it, I got about 3 more minutes of working time out of the mixture and didn't have to toss any Bondo out, it all made it to the frame!!!:brian
    You learn something new every day!:croc
    Nice tip croc, thanks for passing it along.
      cool, good idea.
        Never thought of that,cool tip.
          Bondo smells good....just sayin......great tip Croc !
            Yes it does. I miss working right next to the body shop.
            Justin, HERD member 00016
              great tip, i no i have thrown more in trash than made to item of intent
              Todd Pearson
              Herd #118
              AMA #366336
              SERA #107 (Southern Enduro Riders Assoc)
              08 FLHX, TW555's, TTS Mastertune
                If I had a dollar for every time that happened to me.........
                Good tip. So good, no wonder they don't put it on the can. They make more money when you throw half of it away...!
