I took the Road King out yesterday for the first time since doing the 1000 mile fluid changes (went to see me Mum). I used Mobil1 20W50 for V-Twin in the engine, Spectro Heavy Duty Platinum for 6 speed transmissions in the tranny, and Spectro Heavy Duty Primary Chaincase Oil in the primary. I also changed to a K&P Engineering oil filter. I am pleased to report that shifting is noticeably quieter and easier, with much of the CLUNK gone. Gear whine in fifth, while not gone, is noticeably reduced. Using a different oil in every hole is not as convenient as just using the same thing all the way, and this stuff ain't cheap either, but I am very pleased, so far, with the result.
1000 Mile Fluid Changes
I switched to Mobil 1, Belray trans oil, and primary oil and have never looked back.
Speaking of which, I'm about 40 miles away from doing my 10,000 mile change......
Well there goes another 70 bucks........ :)"Lead paint chips are chewy AND sweet......"
Originally posted by RubberDown View PostI switched to Mobil 1, Belray trans oil, and primary oil and have never looked back.
Well there goes another 70 bucks........ :)herd member #00112
Originally posted by MOTOCROSSER View Posti`ll be switching to mobil 1 for my next oil change RD! I used to use belray in the early 80`s in my motocross bikes!then i switched to golden spectro oils!!
The Mobile 1 I would swear by, I really like it....."Lead paint chips are chewy AND sweet......"
im running redline syn in the primary and transmission ,but regular dino oil in engine.
smoother quieter than before noticable improvement for sure09 Softail Springer FLSTFBT "AKA" Heritage Fatbones Touring
Originally posted by WideOpen View PostI took the Road King out yesterday for the first time since doing the 1000 mile fluid changes (went to see me Mum). I used Mobil1 20W50 for V-Twin in the engine, Spectro Heavy Duty Platinum for 6 speed transmissions in the tranny, and Spectro Heavy Duty Primary Chaincase Oil in the primary. I also changed to a K&P Engineering oil filter. I am pleased to report that shifting is noticeably quieter and easier, with much of the CLUNK gone. Gear whine in fifth, while not gone, is noticeably reduced. Using a different oil in every hole is not as convenient as just using the same thing all the way, and this stuff ain't cheap either, but I am very pleased, so far, with the result.Dale
