My new grips aint right. It sticks for a second when I let off. Its hard to turn the throttle. Will they loosen up in time or have I pinched something. Can I put oil on it?
Grips
Grips
"Life is not a journey to the grave with the intention of arriving safely, in a pretty and well preserved body, but rather to skid in broadside, thoroughly used and worn out, loudly proclaiming, "WOW!!! WHAT A RIDE!!!"Tags: None
Thanks guys Ill take sob back off tomorrow and see what we did wrong.Appalachian Redneck
there is also the possibility that the ferrels aren't seated in the grip properly causing them to drag. could might also be the throttle tensioner
Had mine apart this winter and when I put it back together it was sticking. Found that one of the cables was not adjusted properly (don't remember which). Got them right and grip worked ok. Mine is a 01 F/I if that makes a difference....GlennWhere does it say Humpty Dumpty was an Egg?
Dixie, I read this earlier today but didn't respond, check the cables themselves first, just free the ends up and slide em, if they move freely then the problem is in the adjustment or your binding in the grip, if the cables don't slide 100% freely then you've twisted the cable housing! Twist housing/jacket right or left sliding the cable as you go until cables slide freely, 100% freely!OLD SKOOL BIKERS RULE, WE DO WHAT IT TAKES AND LIKE IT!!!
Originally posted by Ironhead View Postthere is also the possibility that the ferrels aren't seated in the grip properly causing them to drag. could might also be the throttle tensionerHerd Member #87
Originally posted by Dixiecrat View PostMy new grips aint right. It sticks for a second when I let off. Its hard to turn the throttle. Will they loosen up in time or have I pinched something. Can I put oil on it?Where does it say Humpty Dumpty was an Egg?
