What is the use of it specially down South where the temperature can reach 100 degrees?
Harley "Air Temperature" Gauge
hmm.. everything I have ever seen about it says it's just for ambient temperatures.. in other words, the temp outside. I heard the glides were comin with em.. and I have also heard that they weren't very accurate. Do you have one mounted in your dash?
Or atleast I think that is what you're referring to. I don't think there are any intake measurements or anything taken on any Harley.
i reckon its a butt-sweat-o-meter
erbox
erbox
erbox
yup, u should get u an oil temp gauge..
let your sweaty crack tell you how hot it is outside, lolHERD MEMBER #00028
Don't have a clue as to why H-D put that thing there ??? fuggin useless.. But then again they do know that,so that's why they sell other gauges for that. I could go on and on bout stuff they know yer gunna change, that's why they put most of the stock stuff they do.
No huge revelation here tho.HERD MEMBER #0057
If i only had more time..............
I think they had to balance out the dash with that hole and the temp was the cheapest thing they could put in it. it attempts, I think, to give you a temp not affected by airflow or sun heating the fairing. Have noted if your freezing yur ass off, that knowing how cold it "really is" dosnt help much. visa versa heat.THE NEGATIVE ONE no better don't click
I changed that stupid air temp gauge for oil temp gauge a long time ago. Stupid, wasted, gauge. They could have made it useful and put a coffee cup on the cold side and a beer can on the warm side. That way I would know when it was beer thirty.HERD # 00075
