Ok so I'm in need of a Primary Chain oil change.. I really dont want to pay for it, but Ive never done it before ethier..So Ive read a little about it on the net and it seems pretty straight forward.. But I figured Id asked here to see if I got it correct..I have a 08 sporty....
1 Place an oil pan directly beneath the widest portion of the motor's primary housing. Using a Torx driver, remove the oil drain plug directly below the round "derby" cover. Allow the primary fluid to drain completely.
2 Remove the O-ring from the drain plug and discard it. Wipe the tip of the drain plug with a shop towel to remove any dirt or debris that may have accumulated on it. Slip a new O-ring onto the drain plug and reinsert it into the primary housing.
3 Remove the bolts that secure the derby cover to the primary cover with a Torx driver. Pull the derby cover and its gasket away from the primary and set it aside.
4 Pour fresh primary fluid into the primary housing through the derby port, filling the primary until the fluid touches the base of the clutch assembly. Wipe away any spilled primary fluid with a shop towel.
5 Reinstall the derby cover and gasket onto the primary housing, tightening the cover bolts with a Torx driver.
Few more questions are how about how much oil does this take a quart? Can I use mobil one V twin for this?? It says full is when the oil touchs the clutch assembly is that on the kickstand or in the upright postion? Is the clutch assembly visable directly behind the derby cover? Is there anything else that I should know before I attempt this... Sorry for all the newb questions but what can i say but Thx in advance for any input
