The HD dealer gave me one of those LCD oil temp gauges for the RoadGlide. Temps are running 250-260deg according to the gauge! While the wifee was at work today, boiled some water and placed her candy thermometer in and read about 198deg.........put the HD oil temp gauge in and it read about 218deg...........looks like I'm running cooler than I thought! Thought I'd put this out for others who have this gauge!!
LCD Oil Temp Gauge
Originally posted by screwball View PostWater boils at 212*.
Brian I dont think the candy thermo is spot on accurate either. If you really want to know get you a laser temperature gun. You could also put the digital thermo in the pot of water and watch it, as water does boil at 212 degress so see whatr it reads when the water starts to boil.Herd Member #87
good idea Jeff. when the water boils, take the number down and adjust from there. good idea....science is greatTwenty First Herdster
technically water boils at 212 degrees at sea level, it may boil at 198 degrees in the mountains where the air is thinner....just saying.......:) just trying to be a smart assOfficial HERD Member #00144
Sponsored by: Rainrider
Originally posted by wndchsr View PostBrian I dont think the candy thermo is spot on accurate either. If you really want to know get you a laser temperature gun. You could also put the digital thermo in the pot of water and watch it, as water does boil at 212 degress so see whatr it reads when the water starts to boil.OFFICIAL HERD MEMBER #83
Originally posted by TheBoss View PostI was tested with a third device it would get a different readying. The sad thing with temerature is that it's difficult to get an accurate reading. I use a hand held device and the Mrs. electronic ANAL probe and they both have different readings. So, I average out.THE NEGATIVE ONE no better don't click
Originally posted by Bricks View Posttechnically water boils at 212 degrees at sea level, it may boil at 198 degrees in the mountains where the air is thinner....just saying.......:) just trying to be a smart assIt's not "derailed", as long as the last post relates to the post above it...it's just on a different rail, heading into a more interesting direction
wifee went to work so gonna use her other thermometer to see what it says!!! Next time she makes X-mas candy there might be a synthetic taste to her peanut brittle!!:):)OFFICIAL HERD MEMBER #83
Originally posted by BrianS View Postwifee went to work so gonna use her other thermometer to see what it says!!! Next time she makes X-mas candy there might be a synthetic taste to her peanut brittle!!:):)THE NEGATIVE ONE no better don't click
