Brake Pads
  • Brake Pads
    Just pulling in to the drive foot on back brake pedal the pedal goes real MUSH grab the front and trickle the bike in and this is what I found!!!Click image for larger version
ID:	1005198Click image for larger version
ID:	1005199 left pic NO pad right pad had 5/32 left on fitted new pads front & rear before going out again glad it happened when it did & not 10 min early PHEW
    HERD#18
    OOOOHHHHhhh Ya,time fer some new hardware in there for shure.
      Wow... how many miles you have on those pads Ziderman? looks like you lost the complete pad on that one pad......
        Wow! Surprised it did not give you any warning ahead of time.
          I would not be surprised if you find what is supposed to be on that pad in the street out front of your house.
            Had 11,500 on those pads tend to use the front 90% of the time rear is only used pulling up to a stop
            HERD#18
              Yeah that is a pad failure for sure then..... Glad that it did not happen at speed, or in a panic situation. If that was me, I would be on bended knee and thanking someone cause that could have been UGLY....
                Dammit man, don't you ever look at the brake pads???? I check all my bikes once a month........rotors ain't cheap!!!
                  wow you need to change your braking habbits
                  my brakes wear just about even maybe 60-40 fronts over rear.
                  using brakes together is the only way to stop quickly and safely..not to mention the wear factor if you use them together you will get more miles out of both
                  i tend to use my rear mostly while downshifting and then use the front.for emergency stop im on both
                  oh and is the caliper hanging up on one side wearing the pads out more on one side than the other ..?
                    It does look like it is missing.
                      :good
                      I never use the brakes unless it is both.
                        I favor the front, as it's nearly 70 percent of the stopping power on the bike, but in a quick stop, it's both, and fast........and I never skimp on pad quality when buying new, and I avoid ceramic pads also. they tend to eat and heat rotors quickly. The extra pad life isnt worth the rotor.....IMHO
                          Good to know, was leaning that way
                          anyone use Lyndall Z pads?
                            I used the Z pads once on my old Road King...Never again. Not a bad brake up until the first time I rode in rain. Almost splattered in to the car that was well in front of me when I tried to stop and the brakes didn't. They sent me a new set but I wasn't that impressed. Tons of folks love them but not me. I hear the gold pads are better.
                            John
                            Herd member #20
                            2005 Ultra Classic
                              I've had real good luck with the HD replacement pads.... got 30k out of the first set, and the bike saw lots of loaded down runs and it pretty much lives in the mountains.
