speedo on shovel
  • speedo on shovel
    finally getting my shovel back to its former glory and i think my speedo has died... i replaced the cable a while ago and just replaced the drive and took for a ride and the needle on the speedo just spins around in circles! LOL any ideas peoples? It the speedo knackered? Also i had some dramas finding a right hand side speedo drive but eventually found one! apparently there mostly left hand mounted??? any other info to add to this peoples?
    cheers
    I tryed to find some DIY couldnt so far there is this place.
    Get the speedometer for your classic T-Bird or late model Taurus repaired at Scott Speedometer Service Corp. in Pontiac, Michigan.
      friggen long time since I seen or used a mechanical speedo. crap got on the magnets, wornout bearings /bushings causing a rub, magnet may a got loose.
        YUP,What Vlade said.
        If there is a speedo repair shop in Your area it would be best to have them do the repairs,I have heard of people uncrimping them with a screw driver and cleaning them and using a very light grease such as Lubriplate assembly grease{white stuff in a squeeze tube} and then reassembling them and recrimping with pliers.
        It`s a possibility that after going through all this that the bushings could be shot and may have to either take it to a shop for replacement of bushings or a replacement of the whole unit.
        Personally,I think I would try to pry it apart and clean/lube it but thats just Me and My adventuresome spirit.
        Good hearing from ya Shaggz.
          yea and I have chucked one across a shop once after I tried to make it work about a hunerd different ways ,,woreout the put toghetherin parts I dint need to know How fast I was anyway.
            heeheeheeee
              jus one thought hit me fore I sleeped.. If the cable got too long for some reason... New cable, diffrent parts, routing ? This might force parts inside the speedo to bind up and turn different. Might try backin off the cable retaining nut (or lock) and pullin it out a little runnin it and see if it helps.
                Ya man,that would definetely doo it all righty.
