Security System
  • Security System
    I have an issue. Both of my fobs were taken and I was never given the Pin# to the bike. Do I need to buy a whole new security system?
    Harley can reprogram a new FOB for your bike. You have your own PIN but there is another one (factory) that stays with the bike.
      Hey Irish, welcome! If youíve got the fob - you can display the current pin by going through the manual override procedure . Itís in the owners manual (if youíve got it). If you donít just shout and Iíll dig mine out of the side case. I think itíll show if you turn the ignition on, and press the left signal switch (with the fob present) no fob - no display and youíll have to get it reprogrammed.
      What year bike are you trying to figure out?
      Bob
      Official HERD Member #00230
      Westchester County, NY
      '17 FLHXS Street Glide Special
        I don't have the pin. Was never given the pin and I bought the bike used. It's a 2015 street glide special
          The original owner changed the pin and the dealership I bought it from never gave me a pin and said they didn't change the pin when they took over the bike
            Sounds like you need to make a trip to the dealership and hopefully they can get you straight
            1986 FXR 2015 Road Glide
              If your bike has a fob you can change the pin. Itís in the owners manual - but
              with fob present
              turn ignition switch to ign
              cycle off/run switch- run- off - run - off -run
              press left signal switch 2 times - enter pin will scroll through odometer window
              press right turn signal switch one time - turn signals will flash 3 times and current PIN will appear in odometer
              at this point write it down and thatís it or change it by pressing left switch until desired fist digit is entered
              press right signal - new digit is entered and moves to second digit
              repeat until youíve entered new 5 digit pin
              press right signal one final time and release - new pin is entered
              turn stop switch to off ( new pin is entered into module) turn ignition switch off
              Clear and simple right? LOL
              Bob
