Radio Schematic for Harley Davidson
  • Radio Schematic for Harley Davidson
    I am trying to add REAR speakers but been looking all over google and not a good match at all.
    Anyone have one laying around? I have the 2010 Street Glide....
    EDITED this thread with the information
    Got it and here it is...First get the 35 pin from the dealer.
    1 - RT (+) Green
    2 - LT (+) Brown
    24 - RT (-) Light Green/Brown
    25 - LT (-) White/Brown
    If you need more help, post up! Easy to connect...
    I can print it and email it for you from work tomorrow just tell me which email you want it sent to!
    JC
    Is it time for Herdstock yet?!?!?
    Official HERD Member #00162
      I thought about you earlier - Use any...I got everything apart right now. I have three different invitations to ride tomorrow and depending on weather I have tunes or not will make the selection of which group I will head out with!
      Bummer! I'll continue to google something...
        you just looking for the speaker outputs right?
        trace the front speaker wires to the head unit, theres a set of 4 outputs, you want the 2 not in use!
        JC
          JC
            Right....Just looking for the 2 not used. I'm check that diagram and it looks different. Let me take a picture of what I have to work with.
              Right now it looks like I am using 1, 16, 17 and 18 off the harness image below!
                Its not that simple. The doesn't have the rear speakers activated. You'll need the Ultra to non-ultra harness then have the dealer turn on the rears. Just split the front signal and use your amp for the rear. Easy and cheap!
                  That's what I started doing but was hoping to do it right...Bummer!
                    if you split the signal wont it cause the speakers to cut out because then your halving the OHMS ?
                    JC
                      Nope, the split is before the amp. The amp just needs a signal.
                        NOPE parallel is same OHMS,
                        due i really need to go into DEEP detail?
                          Nope not here
                          I have NO clue
                          was just a thought
                          JC
                            I just got 4 speakers from eLPrez, and I suppose the older the bike the fewer the PITA encumberances...I can hook up 2,4,6 or 8 speakers by splitting the feed.
                            Expectations managed for free
                              Done! Now needing a quick ride to see how it sounds!
