Anyone tried these and if so, what's your opinion?
Dyna Beads dynamically balance tires on the move, resulting in a smoother ride, and one that lasts the life of the tire.
Dyna Beads are small ceramic spheres, high in density and perfectly smooth, that travel inside the tire to locate themselves opposite heavy points to eliminate out-of-balance motion.
The result for your customer is not only a smoother ride, but a better look - Dyna Beads eliminate the need for spoke or stick-on weights applied to those beautiful alloys. They can be used with tubes or tubeless tires, and work for scooters as well.
Dyna Beads are 100% environmentally friendly ceramic, impervious to moisture, and non-abrasive to inner liners and tubes. No special air drying is needed, and Dyna Beads can be installed directly into the tire at mounting time, or after, through the valve stem.
