Shifting meh!!!
  • Shifting meh!!!
    After going through town setting off all the car alarms (annoying, it doesn't do it if I ride close to the center line), I got out on the open road only to discover I can't really hear whether I am over or under RPM's in any given gear. My pipes may be a bit loud. Since I am still under the 500 mile mark, I don't want to run it wrong. Any suggestions that don't involve changing exhaust? :new1I try to follow the manuals suggested shift speeds, but it doesn't feel right. Is additional vibration normal for starting a higher gear in a lower RPM?
    ease out on clutch while twisting throttle, when rev limiter kicks in roll off throttle, pull in clutch and shift and repeat
      You can't hear if you are lugging the motor either?
        Did your FXDC come with a tac ?
        Official HERD Member #00135
          No tac.
            To be honest, I'm not quite sure how to tell. I never had this issue with my Sportster.
              I just broke my pig in a few months ago. I found that the suggest shifting speeds were far too slow, I usually added 5 to 10 depending on the gear. I know that I shift whenever I feel like it and now that its broke in I run it out to make it as loud as possible. At least you know when you downshift at too high of speed....the rear wheel lets you know that...haha
              Official HERD Member #00144
              Sponsored by: Rainrider
                I have a 2008 FXD, if I shift and lug the motor mine will vibrate til the rpms come back up.
                    I was thinking the same thing. I went out riding with the manuals suggested shift speeds in mind. They seemed way too low.
                    I do feel this when using the suggested shift speeds.
                      I just can't figure out why they don't put a tach on most of the new bikes. The MoCo has done everything possible to attract new customers. They ain't like riding anything else.
                      It's just a matter of time, and you will feel the bike, for speed, shifting and such...................
                        I agree 100% with Glade, as soon as you get the feel for the new girl you'll be fine! Or you can do like me ............... 5K shifting!!!! Hehehehehehehe
                          Just curious, what kind of exhaust did they put on??? On my old Dyna I had Pythons and I could hear the engine.... and set off alarms a block away!
                          Official Member #00149
                          2 Stinking Trikes, '09 % '11
                          Social Security and Medicare
                          Qualified! 65 and still riding
                          Official Bona fide Geezer
                            I have the V&H Straight Shot HS Slip-ons, SE A/C and the SESRT.
                              like the rest of the HERD said, its a feeling, it'll come to ya...sometimes riding by the lake, i'll be in 5th gear at 30 mph and just lugging along........potato potato potato
                              doesn't hurt anything on the fatty(carb), cant really do that on the glide(injected)
