I will personally vouch for Rick and his work.....
"2010"
PITONIAK'S CYCLE & MACHINE
120 FEDERAL ST. (RT. 9)
BELCHERTOWN MA. 01007
413-323-7772
WWW.PITONIAKCYCLE.COM
PRICES FOR MACHINE SERVICES
: Bore/hone cylinders .010-.020-.030-.040 .050 .060 = $130.00 pr.
:Bore/hone cylinders twin cam 88" to 95" - 96" to 103" (.125" over) = $240.00 pr.
:Cylinders are bored and honed useing torque plates.
: Basic valve job includes disassembly of heads,inspect,clean,glass bead,grind valves,cut seats,lap valves to seats, clean and reassemble with seals . $175.00
: additional head work if needed :
: remove & install & hone to fit, new valve guides $15.00 each
: remove & install new valve seats $ 25.00 each
: cylinder head & intake porting = price varies on port job
:Bore engine cases for big bore cylinders= panhead,shovelhead,evo,twin cam $180.00
: Machine O.E. Twin Cam heads for compression release valves $150.00
:Machine O.E. EVO heads for compression release valves $ 180.00
: Flywheel rebuilding & balancing
: These are labor prices for services -not including cost of parts !
:Complete engine building available = stock & high performance
:powder coating service available
:Diamond cut service available
(more services soon available)
"2010"
413-323-7772
