Dyno Results!!!
  • Dyno Results!!!
    Had the RoadGlide on the Dyno this am........with the Stage I update the Dyno showed 64.58HP and 72.82lbs/torque. After the Dyno and tuning.............69.24HP and 81.16lbs/torque!! A/F ratio sittin at 13.2........can tell a difference in the bike both accelerating and cruising!! Happy with the results!! After the Dyno, they told me with the factory headers the V&H exhaust turned blue/purple from the heat..............got a NEW V&H muffler out of the Dealer!! I've read that in a Dyno Tune, it comes out to about 1HP for every $100 spent. My Dyno Tune was $217 for the 6HP and 10lb/torque gain! Your comments are always welcome!!!! B.
    Your catching up......................
      Scan and post up the report. I want to compare it with mine.
        I'll see if the missus(computer guru) can do that this evening!!!!
          Is that just the stage one down load or dyno tuned
          Official HERD Member #00137
            Dyno tuned!!!!!
                There you go...Something to compare it too.
                  The AIF seems to hold real steady,the results looks good,does`nt seem like 75 horses is enough though,Ya sure there aint some more hidden away in there?????????
                    According to Dave..They did justice on my scoot.....And I'm only 165# and the Mrs. is a whopping 106 which the variation is not much.
                      Waitin on the missus to scan my results!! Very similar but ya show a little more HP and Torque compared to mine!!
