Ok I know there are gonna be some shavings in the oil during break-in, but I can see alot of shavings in the oil. The service dept said its normal but damn! there is alot! Good thing I got the extended warranty!
metal shavings
Originally posted by wolfer887 View PostOk I know there are gonna be some shavings in the oil during break-in, but I can see alot of shavings in the oil. The service dept said its normal but damn! there is alot! Good thing I got the extended warranty!
Shortly after i got my sporty, I did a series of quick oil changes on the bike. ( it was used ) and I started to get fair amounts of shavings myself.
They were brass shavings, and I was nervous that i may have a cam bearing or some other brass bushing going out.
After many consults with Dave63 and others, I tore down the cam chest on the bike to inspect the bushings in the motor..I found "nothing" that indicated a failed component in the motor, and changed the bushings in the cam chest. I also put in new "B" lifters, and replaced rocker arms and rocker shafts while the motor was down..
I have great oil pressure, and never did find the cause of the brass shavings in the motor.
I've put on roughly 10k miles since then, and the motor has been metal free since..
The possibility exists than machine shavings were left inside the motor from the factory, and your now seeing them manifest in the oil changes as the motor breaks in..Might I suggest you look into a lifetime oil filter for the motor, perhaps in J&P cycles catalog, or from "SCOTTS" performance products..
I own one of these filters myself, and swear by the increase in filtering capacity, and how much cleaner the motor is inside.
It would certainly help to catch any of those "questionable" flecks of material you are seeing...U.S. Army "Retired"
Thanks for the info gruss, these are mettalic shavings that I can see and feel, Harley service said for me to wait till 1000 miles and they will change the fluids and it will be fine. Till then this is gonna worry me, but like I said I'm glad there is a warranty!Proud Herd Member #122
2010 Wide Glide Vivid Black
Rush 1.75 Slip-ons
MOOOOO "cough" "cough" MOOOooOOOoooO
Of all of the engines I build for for boats, cars and bikes, there is always some metal in the oil the first oil change. Some are better than others, but it always concerns the people if they are not expecting it.Justin, HERD member 00016
Originally posted by autotec View PostOf all of the engines I build for for boats, cars and bikes, there is always some metal in the oil the first oil change. Some are better than others, but it always concerns the people if they are not expecting it.Proud Herd Member #122
Rush 1.75 Slip-ons
I did my first 1000 mile fluid change today at 971 miles and found very little metal. The crankcase plug and primary plug had a little bead of metallic paste on the magnet and the tranny had virtually nothing. I also put on a K&P Engineering filter that I got from TooBadd back in Feb.
Originally posted by scol View PostOn my sporty the engine lacks a magnet. I was thinking of putting a magnet on the filter. Any thoughts on this?
only because I'm not sure exacly how an external magnet on the filter might impede oil flow internally. Probably not at all, but...
Originally posted by scol View PostOn my sporty the engine lacks a magnet. I was thinking of putting a magnet on the filter. Any thoughts on this?U.S. Army "Retired"
Originally posted by gruss View PostThe lifetime re-usable filters come with a magnet inside the housing of the filter....and they work well !!Be resonable, do things my way.
Originally posted by scol View PostThats a good idea if I was planing on keeping the bike for a long time. I'm still toying with the idea of going to a biger bike if my ecomy picks up.U.S. Army "Retired"
