06 Sportster fluid change
  • 06 Sportster fluid change
    I've changed EVO's and TC but I've never done a Sportster. A friend who I've changed his Road King oil before asked if I'd do his dad's Sportster and how much I'd charge. Is there much difference? I assume that it takes a bit less but I really don't know.
    Thanks,
    John
    John
    Herd member #20
    2005 Ultra Classic
    I'm sure Gruss and many others can tell you. But check this site out....
      http://linson.us/harleydavidson/spor..._oilchange.htm
      good visuals might be some variation in the drain hose. it might just be plastic cliped to another line and have its own plug
        3 qts oil..........3/4 of a qt. primary..........don't forget to oil the filter gasket.
          Sounds simple enough...thanks guys!
          John
          Herd member #20
          2005 Ultra Classic
