last couple times I've been able to get on my scoot, the thing runs like chit. Start it up (full pull on enrichener)
let it sit running for a few minutes (2 or 3), then take off, about another 2 minutes or so, go to half pull, then closed a minute or so later, same as always. but anyway, the thing sounds and runs fine sitting at idle.
once going, if I try giving it too much throttle (getting it) it cuts out, popps, cracks, falls on it's face. I have to very slowly work it to get up to 50mph or so.
once there, I can hammer it, and it will still popp and crack a second or two, but will build up speed, and once I hammer it hard for a mile or so, it seems to run ok, till I am back at slow idle speeds, then if I give it any throttle it does the same thing.
I am thinking this is a lean condition, and haven't had a chance to check anything yet, but I am thinking it could be a bad seal from the carb to the intake....
does that sound like it could be the possible culprit?
