DTC Codes
  • DTC Codes
    As stated in a earlier post on our over night trip, the bike went into limp mode. This was quickly corrected and I pulled the codes this morning.
    P1511 Power management mode
    P2135 TPS correlation error
    U1040 Unknown
    Looks like the ECU missed a throttle position sensor reading and tripped a limp mode trigger. I pulled the cable to the TB and cleaned it, which is most likely the culprit.
    Anyone know what U1040 is ? could not find anything solid on it. Cross reference on other makers seems that it has something to do with ABS.
    Could be caused from having a combination of all the above,thus "Unknown".::zeta
      U1040 is not listed on any DTC code list I have access to at the moment. that I why I put unknown. I agree I feel that they are all a result of same issue. Just curious on the U1040, the other two make sense.
        Found this.
        The U1016 code simply represents the absence of the stock ECM.
        Momentary gauge loss has been reported with a relatively small number of motorcycles using the ThunderMax system. If this condition does occur, simply cycling the main power switch will restore the gauges and lights to normal function. Doing this allows the Turn Signal Security Module or Turn Signal Module (as equipped), the instrumentation, ECM and various other sensors to regain proper synchronization. To date there have been no negative effects in regards to the running condition of the engine if this phenomenon should occur.
        At your convenience it is strongly recommended that you check the motorcycle for Diagnostic Trouble Codes through the odometer and within the ThunderMax SmartLink software. In addition, make sure the battery cables are clean and secure, inspect the ground contacts for proper installation, clean any scale off of fuses and make sure that any non-original electrical accessories wired on the vehicle are not causing this condition. Temporarily removing or bypassing any accessory device may be a valid test.
        So far, we have been unable to reproduce this random event on our test motorcycles with modules that have had this issue in the field. We will continue to monitor and test for a possible cause and, of course, a cure when or if the cause is identified.
        Your account of this event has been recorded and you will be notified of our findings.
        Thanks,
        Randy Dull
        Product Support
          Damn man..guess where my mind was when I saw DTC codes...
          Herd #132
            Yep.... Back to the gutter.... I think the same thing every time I see DTC.
              I don't get it. Is it in here?
              I diamond trading company. All Your Business Needs Here.
              TradingCompanies.info
              Category filter: Show All (85)Most Common (1)Technology (28)Government & Military (21)Science & Medicine (15)Business (17)Organizations (15)Slang / Jargon (3)Acronym Definition
              DTC Design-To-Cost
              DTC Direct-To-Consumer (marketing)
              DTC Depository Trust Company
              DTC Distributed Transaction Coordinator (Microsoft)
              DTC Domain Technologie Control (web hosting control panel)
              DTC Diagnostic Trouble Codes (automotive on-board diagnostics)
              DTC Diamond Trading Company
              DTC Data Transfer Controller
              DTC Direct Torque Control
              DTC Data Technology Corporation
              DTC Delhi Transport Corporation
              DTC Ducati Traction Control (motorcycle technology)
              DTC Direct to Card (printer)
              DTC Dans Ton Cul (gaming clan)
              DTC Defense Trade Controls (US State Dept)
              DTC Denver Technological Center (Englewood, CO, USA)
              DTC Domain Technology Committee
              DTC Drug Treatment Court
              DTC Design Time Control (Microsoft)
              DTC Drug and Therapeutics Committees
              DTC Distal Tip Cell
              DTC Direct to Customer
              DTC Delaware Transit Corporation
              DTC Dossier to China (adoptions)
              DTC Direct Traffic Control
              DTC Defence Teaming Centre (Australia)
              DTC Dansk Toksikologi Center (Denmark)
              DTC Diphtérie, Tétanos, Coqueluche (French: diphtheria, tetanus, and whooping cough; vaccine)
              DTC Depository Transfer Check
              DTC Digital Technical Control (USMC vehicular communications shelter)
              DTC Diagnosis and Treatment Centre (UK)
              DTC Data Transfer Cartridge
              DTC Diverse Technologies Corporation
              DTC Digital Transmit Command
              DTC Digital Traffic Channel
              DTC Digital Trunk Controller
              DTC Desert Test Center
              DTC Development Test Command (US Army Test and Evaluation Command)
              DTC Dead Time Correction
              DTC Date to China
              DTC Deterministic Transitive Closure
              DTC Delivery Term Code
              DTC Desk Top Computer
              DTC Desktop Tactical Computer
              DTC Digital Television Camera
              DTC Data Transfer Coprocessor (microcontroller)
              DTC Distributed Turbo Coding
              DTC Demonstration and Training Centre
              DTC Digital Type Company
              DTC Decline To Comment
              DTC Direct Thermocouple Control
              DTC Desk Top Conference
              DTC Digital Television Controller
              DTC Double Touch Cursor (button on refreshable Braille display)
              DTC Deaf Teen Club (Michigan)
              DTC Chief Dental Technician (Naval Rating)
              DTC Data Communications and Terminal Controllers (HP)
              DTC Defense Training Center (US Defense Logistics Agency)
              DTC Danube Tourist Commission
              DTC Delta Technical Center (Delta, UT, USA)
              DTC Defence Travel Card (Australia)
              DTC Direct to Consignee (air freight industry)
              DTC Denver Transportation Club
              DTC Deuce Trey Cartel
              DTC Department Technology Coordinator
              DTC Display Telecommunications Corporation
              DTC Design Temperature Control
              DTC Distributed Traffic Control
              DTC Dual Temperature Controller
              DTC Destination Terminal Charge (freight)
              DTC Domain Traffic Class
              DTC Design and Technology Computers
              DTC Designated/Division/Directorate Training Coordinator
              DTC DeKalb Teachers College (Dekalb, IL)
              DTC Distributed Termination Condition
              DTC Dumb Terminal Connection
              DTC Detector Test Console
              DTC Digital Transport Communications, Inc.
              DTC Density Time Curve
              DTC Dockyard Test Coordinator
              DTC Digi-Tribe Communications
              DTC Data Transmission Components
              DTC Direct Telecommands
              DTC DPI/TCC Collocation & Consolidation (USAF)
              DTC Destitute Training Centre
                Well after looking at endless opinions after doing a search on multiple engines, the one thing that shows up more often than any is that the U1040 is a serial data error. Then they say this (which makes my blood run cold)
                just ignore it.
                Herd #132
                  DTC is the company that Beer30 retired from. And which I am still an indentured servant at.
                    and man am I glad!! Your time is a comming DDB.
                    Herd #132
                      Forgive my lack of definitions, but is indentured servant anything like a Slave?
                      Herd #132
                        just ignore it.
                        Hmmm... sounds about right. From what I remember the TPS can kick an error sometimes when the connections on the throttle body get corroded or gummed up. So it looks like they all fit together. Dirty connector, U1040 serial data error, TPS correlation error on the throttle body P2135, triggers the limp mode or Power management mode P 1511
                          Ohhhhhhhhhh......... I thought it was something that might have been in the What happened thread.
                            pretty much....
                              Whoops...my bad.
                              Herd #132
