I was WRONG!?
  • I was WRONG!?
    Well, I hate when I am wrong, but I am a man and will admit it. Recently I installed a set of Boogey lights on my bike, I noticed that the first time I rode with them on the fuse for them blew, could not figure out why, and since I am an electrician I knew they could not be wired wrong. Well I should have thought about assuming things, what happened was a stupid mistake, when I plugged the connector in on the tank above the spark plugs the tank was raised up, when I bolted it back down I never saw that the connector was hitting on the motor mount causing a small cut in the wire. What a stupid mistake, but the important thing is that I learned a lesson, and a valuable one at that. :boo
    erboxThe only time I hate it when I'm wrong is when the wife is right.....Glennerbox
      Ha! That is funny. In my wifes mind she is always right!
        I thought I was wrong once, but I wasn't!
        Tommy
        HERD Member #141
        "To ride, or not to ride... THAT is a stupid question!"
          I did the same thing with my luggage rack light, hooked it up and apparently pinched the wing when lockin it into the docking.......OOPS!!
            I married Mrs. Right, I didn't know her first name was Always............................................ ..erbox
              Admitting guilt of wrong...Priceless. :)
                Thanks Boss, at least someone gets a kick out of it!
                  I stay wrong,,, Well it saves getting a big head thinkin I'm always right.
                  Matter of fact I hate it when I'm right.
                    Did you ever think you may be right about that?
                      Good going there Sparky..........glad your not on my crew!!! hehehehehehehe
                        Yep!!! Good lesson there! Pinched wires, hoses etc...cause a lot of problems! Always gotta make sure that its not happenning!
                          I had to work today and I did not make any mistakes, no pinched wires or anything like that. It was a good day!!!!!!!!!!!!!
                            It's nice to have an Electrician on here to Fug with....what do you do? Resid, Comm. or Indust.??????
                            We ain't called Sparky for nothing, the bigger the spark the better the the boom!
                              Only commercial/industrial. I run all the construction electrical work for the Dept. of Energy.
