Does any one have any experience with the vance and hines fuel pak in a twin cam
fuel pack
I know Pro50 sold one to Jirvin on this thread. Pro50 when he gets back on might be able to shed a light.
Originally posted by bigun View PostDoes any one have any experience with the vance and hines fuel pak in a twin camH1E2R8D
i got the fuelpak on my 03 and i have the settings manuel for whatever setup you wanna run. i didnt install it myself and have limited know how about it, but i can read and decypher if ya tell me what yer tryin t o do, maybe i can helpTwenty First Herdster
Originally posted by Rainrider View PostBigun, I have zero experience with the Vance & Hines fuel pac, but I was shootin' the chit with a fella at Skagit HD today who was there because his new 2010 Street Glide was runnin' crappy. The tech came out to discuss it with him and I overheard their conversation. In a nutshell, the Fuel Pac that he had recently installed when he put on the new V & H pipes was malfunctioning. They decided to repalce it with some racing something or other. Maybe V & H is having a problem with them. Are you?Official HERD Member #00137
Originally posted by toorglide View Posti got the fuelpak on my 03 and i have the settings manuel for whatever setup you wanna run. i didnt install it myself and have limited know how about it, but i can read and decypher if ya tell me what yer tryin t o do, maybe i can helpOfficial HERD Member #00137
i had one on my street glide with the stage 1 a/c and rinehart true duals. it worked great and was easy ito nstall and program. i had no issues with it at all. no popping exaust or the like. the only reason i replaced it with the TTS Mastertune was i am installing cams and after that i plan on doing a 107" S&S cylinder swap and the TTS has more tunning features than a fuel pack. it will work good for you with the options you stated. i cant say anything negative about the fuel pack.
hope this helps
toddTodd Pearson
Herd #118
AMA #366336
SERA #107 (Southern Enduro Riders Assoc)
08 FLHX, TW555's, TTS Mastertune
Originally posted by pro50 View Posti had one on my street glide with the stage 1 a/c and rinehart true duals. it worked great and was easy ito nstall and program. i had no issues with it at all. no popping exaust or the like. the only reason i replaced it with the TTS Mastertune was i am installing cams and after that i plan on doing a 107" S&S cylinder swap and the TTS has more tunning features than a fuel pack. it will work good for you with the options you stated. i cant say anything negative about the fuel pack.
hope this helps
toddOfficial HERD Member #00137
Sorry I missed this earlier. I have one, installed it myself. I bought it from Eastern Performance for about $220. I do not have the stage I download, you don't need it if you go FuelPak because they have maps for with and without the download, so save your money if you are getting one. Give me a shout if you have questions, I did all this back in December, have a somewhat different setup than you but not radically so. V-Twin forums also has a HUGE thread on these.
So as a side question. Just because you replace the stock pipe with a V&H high flow 2 into 1 does that mean I'll need to add a fuel pack or mess with that? I have a Screamin Eagle muffler on it now.The hardest part about a Zombie Apocalypse, will be pretending I'm not excited!
Originally posted by WideOpen View PostSorry I missed this earlier. I have one, installed it myself. I bought it from Eastern Performance for about $220. I do not have the stage I download, you don't need it if you go FuelPak because they have maps for with and without the download, so save your money if you are getting one. Give me a shout if you have questions, I did all this back in December, have a somewhat different setup than you but not radically so. V-Twin forums also has a HUGE thread on these.Official HERD Member #00137
I installed on on my 2006 ultra - v&h pipes and free flow air cleaner - install is easy - hardest part is the bolts on the ECU, the inserts slipped inside the plastic and we had to work to get them out. Once installed just plug in the 18 numbers for the map you chose and put the side cover back on. I've been emailing a tech at fuelpak back and forth tinkering with the settings. My mileage dropped from 42 to 33mpg. I've got the mileage back to about 37 but with it came more popping. It's easy as can be to change the settings. What I find irritating is because of EPA regulations you don't know what you are changing, just numbers. I intend to put my bike back to stock. I'd rather have better gas mileage than the few extra HP a stage 1 gives me. I'll prolly sell my fuelpak and pipes once I'm happy with the way the bike is running.
