06 flstf Low beam/running light not working!
  • 06 flstf Low beam/running light not working!
    Low beam bulb Works when I bypass little silver square box on wiring harness. Is this box mandatory? I cannot buy one at H-D dealer .They do not recognize it. Can I remove and straight wire without bulbs blowing continueously? Herd shows one on harness on web site with headlight.
    Welcome to the HERD Rusty.
    I`m thinking the little box might be a relay, can You post us in a pic. of it ?
    The missing link
    http://www.shovelhead.us/
      MrMarty51 Thanks for your time. I will try to post a pic. Its a load resistor I think. Do you know where I can buy one?
      Click image for larger version  Name:	 Views:	1 Size:	1.15 MB ID:	1233042
Name:
        I did a google search on the part number (SB354 Y503), and this came up... a rectifier-diode (link below). But I would have guessed it should have been a relay wired in there. I'm not sure why it warrants 400v, 25 (35) amp. Is it possible that someone else added this before you got the bike, or did someone else work on the bike at some point? Personally, I wouldn't bypass it. Buy a standard relay (four or five bucks) and wire that in, and you'll be fine.
        https://www.inventelectronics.com/pr...ctifier-diode/
        Official HERD Member #00231
        "Blue skies hanging over my head, I got five hundred miles to ride" - RVZ
          Click image for larger version  Name:	relay1on.gif Views:	1 Size:	20.2 KB ID:	1233051
