Well, after reading the clutch lube section, and attempting the prescribed method, (and miserably failing due to lack of skill) I decided to test a new method...
And by new, I mean new to me, as i'm sure this has been done before..
Now i cant say that all clutch cables are designed like this, but on my '05 sporty, the clutch cable is not sealed between the outer housing and the internal clutch cable, where it mounts to the primary case.
So in short, the oil from the primary will pass through the outer casing of the cable, and if you were to get enough pressure, would squirt out of the clutch cable at the top near the lever...
I hope this condition never occurs, but for the sake of lubrication, it makes perfect sense...As i pondered the cleanup of the absolute disaster I had created on the garage floor (back to that lack of skill thingy) It came to me in a short, uncontrolable burst of giddyness..(if thats even a word)..
With the upper end of the cable off, i'll connect my handy vacuum pump to the top of the cable housing, and draw the oil from the primary housing, up through the cable, and into the pump bottle...Effectively, not spilling a single drop of oil onto the floor...(not that it matters, it already looks like the "Exxon Valdez" had run aground in my garage)...
So without delay, i found various hose pieces, and made a connection that i hoped would be air tight enough to allow a vacuum, and made the connection.....I began the pump process, and within 10 seconds, i had primary oil pulling all the way through the cable housing....
When i finished the process, i had maybe a teaspoon full of oil in the pump bottle, and when i removed the hose from the cable housing, the oil began to drain back into the primary, effectively, spilling "0" drops of oil onto the floor....
I suggest you give this method a try, as it worked like a charm, and seems to be my new method, to get oil into the clutch cable and restore that "factory" feel...
Its nice to know that the cable is now slicked up with clean "synthetic" gear oil......g
