Sorry if this seems like a dumb question but, it has been getting progressively harder to shift my bike into neutral while at idle for awhile now, earlier this week I was not able to do it at all...It seems to be shifting fine for the most part otherwise, sometimes it does seem to bind up a little when shifting up and down though. I know the procedure for adjusting the clutch pack and the primary chain, although checking the primary chain at the service about 5k miles ago it seemed fine. Could this just be the clutch needing adjustment?
Clutch - Difficult to Shift Gears
I tried the Mid cable thing,,,shifting got worse,,
Got the servce book out,,,open the derby,,,
Was Butt stank super simple,,,
Still I called Croc to check,,,
Shifts Perfectomundo now,,
I really needed It at Only 4,000 milesHerd #124
Thanks guys....When changed out my bars I only adjusted the new cables, Dave said to always adjust clutch pack and then the cable. It did not even occur to me to do that at the time I was swapping out the bars.
Originally posted by doublej View PostThanks guys....When changed out my bars I only adjusted the new cables, Dave said to always adjust clutch pack and then the cable. It did not even occur to me to do that at the time I was swapping out the bars.OLD SKOOL BIKERS RULE, WE DO WHAT IT TAKES AND LIKE IT!!!
Got the clutch pack adjustment done, adjusted the cables and am able to shift into neutral while bike is stopped at idle now. The bike also shifts way way smoother. Its amazing what happens when you do crap right. :)
Update,,I did a fast 2 gear down shift with a blip Trailing In hard, deep in a corner,,
Full power off the apex,,took a gear with a quarter clutch pull and WOT on the release.
Man My clutch Is perfect.
I can match engine an tranny speed now and make my downshifts to stay In the center
of the power band with no rear tire pull down.Herd #124
