Sportster DTC Diagnostic codes and procedure
This is a sticky topic.
  • Sportster DTC Diagnostic codes and procedure
    2000-2004
    The Diagnostic Mode is entered by turning the ignition from OFF to ON while holding the reset switch in. The normal power-up sequence will occur before entering the diagnostic mode. Diagnostic codes set during this power-up sequence will be stored as well.
    Important Note: Be sure no diagnostic codes are indicated before reset is held in for more than 5 seconds or diagnostic information will be lost.
    When in diagnostic mode the odometer will display the first diagnostic code. When the trip switch is pressed again the next code will be shown. If the trip switch is pressed for more than 5 seconds at any time while in the diagnostic mode, the diagnostic code displayed will be erased.
    There are 7 different diagnostic codes available. They are as follows:
    d01 - Speed sensor power output shorted low
    d02 - Speed sensor power output shorted high or open
    d03 - Not Used
    d04 - Not Used
    d05 - Speed sensor return shorted high
    d06 - Speed sensor return shorted low
    d07 - Not Used
    d08 - Speedometer power over voltage
    d09 - Speed output shorted high
    d10 - Speed output shorted low or open
    CAL XX - Speedometer application calibration number:
    14 = Domestic
    15 = HDI
    When in the diagnostic mode, all codes are displayed in sequence from d01 to d10.
    As a code appears in the display (for instance d02), it will read "d02Set" if set or "d02CLr" if clear.
    The diagnostic mode is exited either by turning ignition from ON to OFF to ON again without depressing the reset switch or if a speed signal greater than 5 MPH is detected.
    Diagnostics cannot be performed if system voltage is less than 9 VDC or greater than 16 VDC. The only exception is d08 which is set when system voltage is greater than 16 VDC.
    After all the diagnostic codes are displayed, the speedometer calibration number is displayed (CAL 14 for example).
    2005-2008
    1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
    2- Push odometer reset button in & hold.
    3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear.
    4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
    5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
    P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
    S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
    SP = speedometer
    T = tachometer
    6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC’s the code will be displayed or the word “none” will appear if there are no DTC’s. Push the odometer reset button again to view additional codes if they exist.
    7 - Record the codes.
    8 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
    NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 9. If the code is current it will reappear.
    9 – Press and release the odometer reset button to continue to the next module.
    10 – Turn Ignition switch to OFF.
    On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier is selected.
    "No Rsp" will also appear if the run/off switch is in the off position when doing this procedure.
    HFSM = Hands Free Security Module
    TSM = Turn signal module
    Priority/DTC/Fault condition
    1. P0605 ECM FLASH Memory Error
    2. P0603 ECM EEPROM Memory Error
    3. U1300 ECM Serial Data Low
    4. U1301 ECM Serial Data High
    5. U1097 Loss of Speedometer Serial Data to ECM
    6. U1064 Loss of TSM/FSFM Serial Data to ECM
    7. P1003 System relay contacts open
    8. P1002 System Relay Coil High/Shorted
    9. P1001 System Relay Coil Open/Low
    10. P1004 System Relay Contacts Closed
    11. P1009 Incorrect Password
    12. P1010 Missing Password
    13. P06415 V+Vref 1 Out Of Range
    14. P06515 V+Vref 2 Out Of Range
    15. P0373 CKP Sensor Intermittent
    16. P0107 Map Sensor Open/Low
    17. P0108 Map Sensor High
    18. P0374 CKP Sensor Synch Error
    19. P1600 EFI Module Processor Internal Error
    20. P1270 TGS Validation Error
    21. P2107 EFI Module Processor Internal Fault
    22. P2122 TGS1 Low/Open
    23. P2123 TGS1 High
    24. P2127 TGS2 Low/Open
    25. P2128 TGS2 High
    26. P2138 TGS Correlation Error (Twist grip sensor)
    27. P0120 TPS1 Range Error
    28. P0220 TPS2 Range Error
    29. P0122 TPS1 Low
    30. P0123 TPS2 High/Open
    31. P0222 TPS2 Low
    32. P0223 TPS2 High/Open
    33. P2135 TPS Correlation Error
    34. P2119 EFI Motor Throttle Body Range Performance
    35. P2100 EFI Motor Circuit Open
    36. P2101 EFI Motor Circuit Range Performance (Actuation Error)
    37. P2102 EFI Motor Circuit Low
    38. P2103 EFI Motor Circuit High
    39. P2176 EFI Closed Position Not Learned
    40. P1514 Air Flow Fault
    41. P2105 EFI Forced engine shutdown
    42. P1501 Jiffy Stand Sensor Low
    43. P1502 Jiffy Stand Sensor High
    44. P0572 Brake Switch Low
    45. P0117 ET Sensor Low
    46. P0118 ET Sensor High
    47. P0112I AT Voltage Low
    48. P0113I AT Voltage Open/High
    49. P1351 Front Ignition Coil Driver Open/Low
    50. P1354 Rear Ignition Coil Driver Open/Low
    51. P1352 Front Ignition Coil Driver High/Shorted
    52. P1355 Rear Ignition Coil Driver High/Shorted
    53. P1357 Front Cylinder Combustion Intermittent
    54. P1358 Rear Cylinder Combustion Intermittent
    55. P0261 Front Injector Open/Low
    56. P0263 Rear Injector Open/Low
    57. P0262 Front Injector High
    58. P0264 Rear Injector High
    59. P0562 Battery Voltage Low
    60. P0563 Battery Voltage High
    61. P0501 VSS Sensor Low
    62. P0502 VSS Sensor High/Open..
    63. P1356 Rear Cylinder No Combustion
    64. P1353 Front Cylnder No Combustion
    65. P0444 Purge Solenoid Open/Low
    66. P0445 Purge Solenoid High
    67. P1475 Exhaust Actuation Position Error
    68. P1477 Exhaust Actuator Open/Low
    69. P1478 Exhaust Actuator Shorted/High
    70. P0131 Front Oxygen Sensor Low
    71. P0151 Rear Oxygen Sensor Low
    72. P0132 Front Oxygen Sensor High
    73. P0152 Rear Oxygen Sensor High
    74. P0134 Front Oxygen Sensor Inactive
    75. P0154 Rear Oxygen Sensor Inactive
    76. P1510 EFI Limited Performance Mode
    77. P1511 EFI Power Management Mode
    78. P1512 EFI Forced Idle Mode
    79. P0577 Cruise Control Input High
    1. U1300 Serial Data Low
    2. U1301 Serial Data High
    3. U1016 Loss of ECM Serial Data
    4. U1255 Serial Data Error
    5. B1142 Smart Security System Internal Fault
    6. B1135 Accelerometer Failed
    7. B1136(HFSM) Accelerometer Tip Test Error
    8. B1151 Bank Angle Sensor(BAS) Short to Ground
    9. B1152 Bank Angle Sensor(BAS) Short to Battery
    10. B1153 Bank Angle Sensor(BAS) High
    11. B1154 Clutch Switch Input Short to Ground
    12. B1155 Neutral Switch Input Short to Battery
    13. B1134 Starter Output High
    14. B1121(TSM) Left Turn Output Fault
    B1121(HFSM) Left Turn Output Open
    15. B1122(TSM) Right Turn Output Fault
    B1122(HFSM) Right Turn Output Open
    16. B1123(HFSM) Left Turn Output Short to Ground
    17. B1124(HFSM) Right Turn Output Short to Ground
    18. B1125(HFSM) Left Turn Output Short to Battery
    19. B1126(HFSM) Right Turn Output Short to Battery
    20. B1143(HFSM) Security Antenna Short to Ground
    21. B1144(HFSM) Security Antenna Short to Battery
    22. B1145(HFSM) Security Antenna Open
    23. B0563 Battery Voltage High
    24. B1131(HFSM) Alarm Output Low
    25. B1132(HFSM) Alarm Output High
    26. B1141(TSM) Ignition Switch Low/Open..
    B1141(HFSM) Ignition Switch Low/Open
    __________________
